2006 Ford Taurus Rear Thumping Noise
ARTMOSHER
2006 ford taurus, 24000 miles.
there is intermittent thumping noise in rear of car.
it is not the spare tire rattling.
it occurs on smooth roads.
muffler appears to be tight.
nothing feels loose or able to rattle when i crawled under car
not constant or regular, so i guess not tire
Nov 26, 2006 at 4:09 AM
  • 55,781 POSTS
Sounds like you have a strut or a sway bar link that has gone bad. Check both and let me know, thanks for the donation :D
Nov 26, 2006 at 7:18 AM
ARTMOSHER
ken was correct, thumping noise caused by bad strut.
fixed under warranty
Dec 11, 2006 at 9:18 AM
  • 55,781 POSTS
You are very welcome. :D
Dec 12, 2006 at 5:46 AM
Suggested Repair
Inspect the rear struts and sway bar links. The intermittent rear thumping was confirmed to be a bad strut and was fixed under warranty.
Conversation Summary
A 2006 Ford Taurus with 24,000 miles had an intermittent thumping noise from the rear on smooth roads. The spare tire, muffler, and other underbody parts did not appear loose, and the noise was not constant. An expert suggested a bad strut or sway bar link. The owner later confirmed a bad strut was the cause and that it was repaired under warranty.
