1996 Ford Taurus Howling Noise
SBELASCO
1996 Ford Taurus with 140000 miles. There is a howling noise coming from below the car. Noise starts around 20 mph and does not change pitch even at speed put into neutral. Does not vary with engine speed. I can feel a slight vibration in the steering wheel, very slight more like a buzz.
Mar 25, 2007 at 10:52 AM
MERLIN2021
  • 17,250 POSTS
sounds a bit like a wheel bearing try getting it up to speed then turning the wheel quickly right and left, see if the noise quets down any if yes wich ever way you turn to silence it replace the opposit bearing!
Mar 25, 2007 at 1:35 PM
SBELASCO
Merlin2021 - thanks for the help, the noise stops in a quick left turn but not a right turn so I replaced the right wheel bearing but the howling continues. The noise seams to be more concentrated on the drivers side. I think I'll replace the left side and see what happens.
Mar 31, 2007 at 11:57 AM
MERLIN2021
  • 17,250 POSTS
let me know how ya do!
Mar 31, 2007 at 2:57 PM
SBELASCO
Replaced the left wheel bearing and the noise is gone. So a quick left turn that silenced the howling noise meant to replace the same side bearing as I see it. Thanks for response that verified what I thought it was.
Apr 1, 2007 at 6:43 AM
Suggested Repair
Replace the driver's side (left) wheel bearing. A howling noise that quieted during a quick left turn was not fixed by the right bearing; replacing the left bearing eliminated the noise.
Conversation Summary
A 1996 Ford Taurus with 140,000 miles had a howling noise from below the car starting around 20 mph. The pitch did not change with road or engine speed, including in neutral, and there was a slight steering-wheel buzz. A quick left turn silenced the noise. Replacing the right wheel bearing did not help, but replacing the left wheel bearing eliminated the howling.
