My daughter has a 1995 Ford Taurus,112,000 miles, 3.0 engine and auto trans. Recently she was driving it when it started to overheat. She parked it immediately. It was leaking coolant from the engine-transmission junction. I checked it the next day. The radiator cap was tight, but the radiator filler tube was packed solid with dirt. The radiator had been replaced about a year ago.
One car repair shop said it was probably a ruptured freeze plug (without actually seeing it) and another said it could possibly be a hose or line on the engine.
The coolant appears to be coming out of the cover plate area on the bottom of the transmission where it is bolted to the engine, so I'm thinking a freeze plug popped due to pressure build-up from the radiator cap being clogged.
Any ideas???
Any ideas???
Apr 18, 2007 at 7:21 AM
