Ford Taurus 1997 ---Coolant Leaking
AMITSINGH000
Its 163000 miles old.I have a problem , whenever I drive 10 -15 miles and stop the antifreeze comes out from the car and the reservoir gets empty. I checked it with mechanic they replace the cracked cyllinder head. But still it has the same problem. Now they are saying , water pump is the problem,and you have to replace it. Can you please suggest whats the problem?
Nov 23, 2007 at 6:54 AM
MERLIN2021
  • 17,250 POSTS
I suggest your mechanic may be one of the problems...get a preesure test of the cooling system, it will reveal were the leak is comming from. Go to a radiator specialty shop, they do this all day long!
Aug 21, 2020 at 6:40 AM
HITEKREDNEK
  • 7 POSTS
Take merlin2021's advice and get the system pressure tested.
The overflow bottle itself could be the problem. My 97 started losing coolant and the one place I didn't look was the overflow bottle.
Once I pressure tested it, the overflow bottle looked like a lawn sprinkler...
If that's your problem, they're still available at Ford for about $40.
Hope this helps.
MERLIN2021
  • 17,250 POSTS
http://www.rockauto.com/
Available on the internet, and they take paypal, if it is the bottle and in my own car it was...17.00!
PETEFORD98
[quote:2990924022="Hitekrednek"]Take merlin2021's advice and get the system pressure tested.
Hope this helps.[/quote:2990924022] ok if this is your problem you can order overflow bottle from advanced auto for about around 10 bucks ,i had this happen to me hope this helps you
