2001 Ford Taurus Radiator Leak
I have a couple of questions really, I have a 2001 Taurus 3.0L Vulcan with 330,000 km (I'm in Canada) and I have a radiator that has a leak on one of the end tanks. I can see the fluid is leaking from that seam, are those repairable? Also, to remove the rad itself, do you need to evacuate the A/C? I have a line that goes into the rad with a strange fitting that I am not sure what it is for, it curls around to the front side of the rad on the passenger side of the car, is that a PS cooling line or what? I'm wondering how involved it is if I need to do it in my own garage with less tools or at my Dad'd (more tools) or sending it to a repair shop (pricey!!!!) Your help is appreciated!
Sep 13, 2007 at 8:34 AM
With 330,00km I think I would replace the whole radiator, not just a sde tank. No you don't need to decharge the A/C! The other lines you see are tranny cooler and A/C Condenser, they are not a part of the engine antifreeze system. If you are getting rid of the car, it is possible to replace the side tank.
Sep 13, 2007 at 9:01 AM
Suggested Repair
Replace the whole radiator rather than only the leaking side tank, given the high mileage. A/C discharge is not required. The extra lines are the transmission cooler and A/C condenser, not engine coolant. A side-tank replacement is possible only if the car is being disposed of.
Conversation Summary
The owner of a 2001 Ford Taurus 3.0L with 330,000 km asked whether a leaking radiator end tank can be repaired, whether the A/C must be evacuated to remove the radiator, and what a line curling to the passenger-side front is. The expert recommended replacing the whole radiator at that mileage, said A/C discharge is not required, identified the lines as the transmission cooler and A/C condenser, and noted a side tank can be replaced if the car is being gotten rid of.
