How to Replace a Car Radiator
A radiator removes heat from the engine through thermal heat exchange using coolant as a conductor and is usually located in the front of the vehicle under the hood. A cooling system consists of many parts including a thermostat, water pump and cooling hoses. A radiator is manufactured with a thin aluminum core coupled with plastic tanks which are prone to coolant leaks. When removing the radiator leaving the cooling fans attached and transferring them onto the new radiator while on the bench could be more efficient. While the radiator is removed use a garden hose to clean the area including the air conditioner condenser.
Tools and Supplies Needed
  • Replacement radiator
  • Engine coolant
  • Socket set
  • Wrench set
  • Hose clamp removal tool or channel locks
  • Shop towels
  • Fluid catch basin
  • Protective eyewear and gloves
Best Practices
  • Disconnect battery cable to avoid short circuits.
  • Replace the thermostat when changing a radiator.
  • Flush the cooling system and install new coolant to protect gaskets and internal engine parts.
  • Replace upper and lower radiator hoses.
  • Inspect the cooling fan operation.
  • Inspect and remove debris such as plastic bags in front of the front grill area.
Let's Jump In!
With the engine cold (only) locate and remove the radiator cap, a small amount of pressure maybe released when loosened.
remove radiator cap
Once the cap has been turned counter clockwise while pushing downward, lift the cap from the radiator.
radiator cap removed
Remove lower shield mounting bolts while removing shielding. This will allow access the bottom of the radiator.
remove lower shield mounting bolts
After removing the lower shielding, locate the radiator drain plug and start to loosen.
loosen radiator drain plug
Coolant will start draining from the radiator drain. Use a catch basin to collect the coolant to be recycled.
coolant draining
Remove the mounting bolts or clips holding the air intake and the plastic fascia over the radiator and lift the cover from the engine bay. Also move the air intake away from the work area.
remove air intake
Locate and remove coolant reservoir mounting bolts.
remove reservoir mounting bolts
Remove the coolant overflow tube from the radiator neck. This hose can become stuck so a twist could be necessary. Once free, remove the coolant reservoir from the engine bay.
remove overflow hose
Watch the Video!
Please watch this video of the job being done, then continue down the guide to glean additional helpful information.
Locate and disconnect the cooling fan electrical connector.
disconnect fan connector
Using a hose clamp removal tool or channel locks loosen the upper radiator hose clamp.
loosen upper radiator hose clamp
Grasp the upper hose and twist to remove.
remove upper radiator hose
Next, remove all cooling fan mounting bolts.
remove cooling fan mounting bolts
After the cooling fan mounting bolts have been removed, gently lift out the fan and housing, sometimes the cooling fan will need to be removed with the radiator.
remove cooling fans
Using a wrench loosen and remove the automatic transmission cooler lines from the radiator, there should be two of them, this is for automatic transmission cars only.
loosen transmission cooler line
Once the transmission lines have been removed, locate the radiator mounting bolts and remove.
remove radiator mounting bolts
After the radiator mounting bolts have been removed, move the radiator forward to remove the air conditioner condenser from the radiator. This condenser will remain in the engine bay so vacuum down and recharge is not necessary. Some condensers are held independently of the radiator in which case you can skip this step.
remove condenser mounting bolts
Using a hose clamp removal tool or channel locks loosen and remove the lower radiator hose. A small amount of coolant might leak from the hose, be ready with a fluid catch basin.
lower radiator hose removed
Double check all hoses, mounting bolts and clips have been removed, gently lift the radiator from the engine bay.
removing radiator
Once the old radiator has been removed, un-box the new radiator and match it up to the old radiator. Look for mounting clips. mounts and transmission lines that might need to be transferred over.
new radiator
Gently install the new radiator. Be careful not to damage the radiator core while installation is occurring.
install new radiator
Once these steps have been completed, reverse the order to reinstall the new radiator. Refill the system with coolant and start the engine, allow the engine to warm up completely while adding coolant until the thermostat opens.
refill radiator coolant
Reinstall the radiator cap by pushing down and turning it clockwise until tight, also check the coolant reservoir fluid level. After installing the radiator cap, recheck the system for leaks, also recheck  the coolant reservoir after a couple of days of operation. Once driving the vehicle, check the temperature gauge for overheating.
radiator cap
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
