99 Ford Taurus Brake Drum stuck
1999 FORD TAURUS
THF05
I have tightened the adjuster wheel on the rear brake shoes to tight and cannot get the drum off. Is there an easy way to release the tension off of the brake shoes.
Sep 17, 2007 at 12:15 AM
SERVICE WRITER
  • 9,123 POSTS
IF the plug is still removed on the backing plate, use a flash light to see where the dog is that hold the adjuster wheel from turning. With a thin tool-screwdriver?, push it back and the use another screwdriver or brake adjusting tool to turn the wheel.
Sep 17, 2007 at 12:49 AM
