'96 Taurus-Cooling Fan ALWAYS ON!
BRADTAURUS
  • 1996 FORD TAURUS
I have a '96 Taurus, 3.0 liter engie, 150,000 miles and the battery keeps dying because the cooling fan doesn't shut off. If their is a quick fix I sure would appreciate it! I have no manual because I bought the car used. Thanks in advance, Brad
Saturday, November 10th, 2007 AT 9:09 PM
BLACKOP555
  • 10,371 POSTS
Look at the relay box and find the aux fan relay.
__________________
Also if those are good disconnect the coolant temp sending unit, does that turn the fan off? If so have it checked.
Sunday, November 11th, 2007 AT 8:27 AM
BRADTAURUS
Thanks a bunch. Now all I have to do is locate what you just mentioned ;o)
Sunday, November 11th, 2007 AT 7:44 PM
BLACKOP555
  • 10,371 POSTS
Usually mounted near radiator. Follow wires from fan motor.
Sunday, November 11th, 2007 AT 9:00 PM
BRADTAURUS
Thanks amigo! I just read in another site that it was probably the Constant Control Relay Module. I went out and found it attached to the battery box and gave it a few raps. The fan shut off so I guess the relay was stuck. Off to the Ford Dealership to get another I guess. Thanks again for your help!
Brad
Tuesday, November 13th, 2007 AT 3:15 PM
BLACKOP555
  • 10,371 POSTS
U most welcome, and thanks for the followup.
Tuesday, November 13th, 2007 AT 6:40 PM
