2000 Ford Taurus AC Fan Only Works on High
ROBEREX
Hi Guys:
All of a sudden my 2000 Ford Taurus, mileage appx 48,000, V6 has a problem. It started when the right passenger side vent started making a chirping noise.
Then the fan switch did not work any more, except in position # 4. So we can only get a high volume of cold air through the air conditiong vent. Any suggestions?
Thanks,
Nov 2, 2006 at 2:29 AM
BRUCE HUNT
  • 3,754 POSTS
I would say that the reostat (spelling) on the switch is at fault and since 4 is high and passes voltage straight through it still works. Replace.
Nov 2, 2006 at 2:50 AM
ROBEREX
You guys a refast and good. Thanks!
Nov 2, 2006 at 6:26 AM
Suggested Repair
Replace the blower fan switch. The rheostat is likely failed; high (position 4) still works because it passes voltage straight through.
Conversation Summary
A 2000 Ford Taurus began chirping from the passenger vent, then the blower worked only in position 4 (high). The expert said the switch rheostat is at fault because high speed bypasses it, and recommended replacing the switch. The owner thanked the responders.
