1999 Ford Taurus Fan Only Blows on High
BLYSTLUND
We have a 1999 Ford Taurus and when we run the Heater/Air conditioner it will only blow when the fan switch is turned to the "high" position. It has 4 settings but again it will only blow the air when it is in the highest position on the fan switch. I hope i explained this right. Thanks in advance for your response.
May 22, 2006 at 11:42 PM
LOSONE
  • 1,616 POSTS
You have a bad blower resistor. Let the glove box open all the way by releasing the side clips. Look on the left side of the plenum assembly and you will see a connector with 5 or 6 wires. Take out the 2, 7mm screws and replace the resistor assy with a new one. That will fix the problem.
Common Ford failure and about a $15.00 part or cheaper. Good Luck!!
May 23, 2006 at 7:40 AM
Suggested Repair
Replace the blower motor resistor. Open the glove box fully by releasing the side clips, locate the 5- or 6-wire connector on the left side of the plenum, remove the two 7mm screws, and install a new resistor assembly.
Conversation Summary
The owner of a 1999 Ford Taurus reported that the heater and air conditioner blower only works when the fan switch is set to high, not on the lower settings. The expert identified a failed blower resistor, a common Ford issue, and advised replacing the inexpensive resistor assembly behind the glove box.
