2002 Ford Taurus Fan Controls Dead
GALE
  • 5 POSTS
2002 Ford Taurus SE mileage: 79,000 My Interior Fan controls for the Air Condition, Heater, Defrost etc will not come on. so nothing will work. what could be wrong with it?
Apr 15, 2007 at 9:45 AM
TAURUSWHEEL
  • 718 POSTS
digital controls or manual controls???
Apr 15, 2007 at 11:21 AM
GALE
  • 5 POSTS
there manual controls :)
Apr 15, 2007 at 11:26 AM
TAURUSWHEEL
  • 718 POSTS
Probably one of three things, first check the fuse or breaker, two check the fan motor itself, apply 12 volts to the fan plug see if it works, three, could be the resistor block is bad.. check one and two first.. the fan motor is not hard to access, if you had a repair manual of some type..
Apr 15, 2007 at 11:42 AM
GALE
  • 5 POSTS
Nopes, no repair manuals here and not sure i could do all that anyways...i'll will take it to the repair shop tomarrow, thank you for your help!!! :D :wink:
Apr 15, 2007 at 12:03 PM
TAURUSWHEEL
  • 718 POSTS
Good luck
Apr 15, 2007 at 12:13 PM
GALE
  • 5 POSTS
Thank you, i'll let you know what the problem is/was when i find out :)
Apr 15, 2007 at 12:20 PM
GALE
  • 5 POSTS
I got my car back from the shop, fast huh Woot!!..it was the Blower Motor just like you said TaurusWheel !! thank you again :D
Apr 17, 2007 at 4:19 PM
Suggested Repair
Check the blower fuse or circuit breaker and the blower motor first, then the resistor block if needed. The shop confirmed the failed blower motor was the cause and replaced it.
Conversation Summary
A 2002 Ford Taurus owner reported that the manual interior fan controls for air conditioning, heat, and defrost did not work at all. The expert suggested checking the fuse or breaker, testing the blower motor with 12 volts, and considering a bad resistor block. The owner took the car to a shop, which found the blower motor had failed.
