Accelerator sticks - not slowing down?
RONRON61
We found no vacuum leaks. However a friend suggested to disconnect battery so the computer would go back to factory settings. Evidently the computer didn't realize that new parts had been added. Now all seams to be operating correctly. Thanks for your input and help!
Ron
Friday, August 21st, 2020 AT 1:57 PM (Merged)
  • 109,913 POSTS
DAVID JIMENEZ2
  • 16 POSTS
I have the exact same problem and have also r/r the TPS and repaired all vacuum leaks (that I could find -r/r PCV valve and hose). Also disconnected the battery to reset ECM and problem is still the same. It's EXACTLY as described by LENREIS.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,571 POSTS
Hey DAVID,
Please clear the computer codes and disconnect the battery for at least 30 minutes, this will help clear the adaptation.
Here is a guide to help you clear the codes.
https://www.2carpros.com/articles/check-engine-light-clear-codes
Please let us know happens so it will help others.
Best, Ken
DAVID JIMENEZ2
  • 16 POSTS
Steve W. Helped me out. Turns out I was given the wrong idle air control valve.... After much experimentation.
https://www.2carpros.com/questions/in-gear-i-release-the-gas-pedal-but-the-rpms-dont-decrease
KEN L
  • 48,571 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
