2005 Ford Taurus Sticky Accelerator
RONRON61
We found no vacuum leaks. However a friend suggested to disconnect battery so the computer would go back to factory settings . Evidently the computer didn't realize that new parts had been added . Now all seams to be operating correctly. Thanks for your input and help!!!
Ron
Aug 21, 2020 at 6:57 AM (Merged)
  • 110,248 POSTS
DAVID JIMENEZ2
  • 16 POSTS
I have the exact same problem and have also r/r the TPS and repaired all vacuum leaks (that I could find -r/r PCV valve and hose). Also disconnected the battery to reset ECM and problem is still the same. It's EXACTLY as described by LENREIS.
  • 55,758 POSTS
Hey DAVID,
Please clear the computer codes and disconnect the battery for at least 30 minutes, this will help clear the adaptation.
Here is a guide to help you clear the codes.
https://www.2carpros.com/articles/check-engine-light-clear-codes
Please let us know happens so it will help others.
Best, Ken
DAVID JIMENEZ2
  • 16 POSTS
Steve W. Helped me out. Turns out I was given the wrong idle air control valve.... After much experimentation.
https://www.2carpros.com/questions/in-gear-i-release-the-gas-pedal-but-the-rpms-dont-decrease
  • 55,758 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Suggested Repair
Clean the throttle body and plate, then install the correct IAC valve (Ford 1F1E-9F715BA, with no spring or bushing). Reset the ECM by disconnecting the battery so it can relearn idle. If the engine returns to idle normally in Park but coasts excessively in gear, ask a dealer about a PCM software update.
Conversation Summary
A 2005 Ford Taurus had a sticking accelerator and high idle that cleaning the throttle body only partly resolved. Testing showed the installed IAC was the wrong spring-loaded design; the correct OEM valve without a spring or bushing fixed the sticky throttle after an ECM reset. A remaining slow deceleration in gear, despite normal response in Park, was suspected to be a PCM programming characteristic rather than a mechanical throttle fault.
