Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Engine Cooling
Coolant Reservoir
Replace/Remove
2002 Ford Taurus - coolant reservoir
2002 FORD TAURUS
ALEXANDERZACHARY
MEMBER
1 POST
How do I replace the Coolant Reservoir on a 2002 Ford Taurus?
Thank you!
Oct 21, 2007 at 1:26 AM
MERLIN2021
Experienced Mechanic
Drain the system below the Degas bottle, Use a pliers to remove the 2 upper hoses, then the lower hoses. Unbolt the 10mm screw and nut then lift out!
Oct 21, 2007 at 1:46 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
