need to drain and flush radiator but cannot find a drain plug. If there is one where? If not how do i go about draining radiator?
Nov 18, 2006 at 5:36 AM
Look for the radiator drain plug on the bottom of the radiator in either corner, sometimes on the engine-facing side. Remove any plastic under-shield that blocks access. Only if the plug cannot be found, disconnect the lower radiator hose to drain the coolant, though this is messier and drains less completely.
The owner of a 1999 Ford Taurus with 81,000 miles could not find a radiator drain plug and asked how to drain and flush the radiator. The expert said the plug is on the bottom of the radiator in either corner, sometimes facing the engine, and may be hidden by a plastic shield. Removing the lower hose was mentioned only as a last resort because it is messy and does not drain the system as well.
