2001 Ford Taurus SES little heat
COREY47
  • 2001 FORD TAURUS
I have replaced the water pump, radiator cap, temperature control switch and 3 fuses. Checked tha actuator - working ok. Flushed heater core - water goes through. Still only luke warm heat. Could the heater core still be the problem?
Friday, November 16th, 2007 AT 6:18 PM
TAURUSWHEEL
  • 718 POSTS
Check the heater bypass hose behind the engine in front of the core, a lot of cores have been plugged, when system is flushed, water takes the easy way thru the bypass and the core doesn't get a full cleaning. If this is definitely not your issue, check the blend door operation to make sure you're getting full heat.
Friday, November 16th, 2007 AT 8:16 PM
