2000 Ford Taurus thermostat/ head gasket 2000 Ford Taurus
ANNQUILES
  • 2000 FORD TAURUS
  • 6 CYL
  • FWD
  • 114,600 MILES
I would like to know if one thing has to do with the other. Went to change the thermostat because car didn't have heat. They changed the thermostat and I have heat but now the car is shaking and the engine light went on and they checked and said it was the head gasket
Monday, December 8th, 2008 AT 10:03 AM
RENAUDTN
  • 636 POSTS
What's the trouble code(s)?
What maybe happened (it is pure supposition on my part though) is that when they replaced the thermostat, some air got trapped behind it which prevented it from opening. As a result your engine overheated and the headgasket blew.
Now it could be completely unrelated as well. There's no way to know for sure.
If you come back with the code(s) it would help to understand what's going on with your car.
Monday, December 8th, 2008 AT 1:44 PM
ANNQUILES
Where would I get the codes from. And is this something worth fixing or am I going to have more problems
Monday, December 8th, 2008 AT 4:34 PM
RENAUDTN
  • 636 POSTS
You can go to autozone, o'reilly, advanced auto, etc
Usually they can retrieve the codes from your car for free.
If you do have a blown head gasket, it could cost you up to $1500 to have it fixed, depending on your engine.
So it is up to you to decide if it is worth fixing it.
If you do decide to have it fixed, make sure you go to a reputable shop; if a head gasket job is not done properly, the new gasket will fail prematurely.
Hope this help
Tuesday, December 9th, 2008 AT 8:54 AM
