Head gaskets change
233,161 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
JWALKER1979
  • 6 POSTS
I changed the head gaskets on my 3.0L Ford Taurus, now it will not run or start up. It is getting fuel and spark. I double checked all electrical connections and the fuel rail everything is plugged in. I installed new spark plugs and checked all of the spark plug wires. The timing on wires seems to be right it does not crank hard. I hooked it up to a scanner and it is not showing any codes. Any advice on as what is wrong?
Apr 5, 2016 at 3:43 PM
CAR-MAN145
  • 321 POSTS
Did you check the compression?
Apr 5, 2016 at 6:06 PM
JWALKER1979
  • 6 POSTS
Yes, the compression is within specs.
Apr 5, 2016 at 6:57 PM
CAR-MAN145
  • 321 POSTS
Then I would think it would have to be timing if you have spark, fuel and compression then it should start unless there is not enough fuel or the timing is off. Try using starter fluid to start it that would tell us if it a fuel problem.
Apr 5, 2016 at 8:16 PM
JWALKER1979
  • 6 POSTS
I am pretty sure it is not timing related. The timing was never messed with. I think it is the mass air flow sensor. It seems to be getting too much fuel. I pulled the plugs after every time of trying to start and the plugs are soaking wet with fuel.
Apr 6, 2016 at 12:52 PM
  • 31,937 POSTS
If the heads off, the valve timing is affected, sounds as if this may be the issue, re check valve timing first, with the hard cranking it may be set to far advanced.
Apr 12, 2016 at 7:28 AM
JWALKER1979
  • 6 POSTS
Issue is resolved. Number one and five on coil were dead. Spark on 2, 3, 4 and 6 all were really weak. Put a new coil on and the car runs great. Thanks for everyone's advice.
Apr 12, 2016 at 12:20 PM
  • 31,937 POSTS
ok, thanks for the feed back, good to see it was an easy fix......
Apr 12, 2016 at 11:10 PM
JWALKER1979
  • 6 POSTS
Just crazy that the coil failed after the engine was taken apart. Lol
Apr 13, 2016 at 8:00 AM
  • 31,937 POSTS
not that odd really, we see these things all the time, fix something and something else lies down and dies, hopefully that the end of it for you.
Apr 13, 2016 at 6:47 PM
JWALKER1979
  • 6 POSTS
Oh it's the end of it on this car. Told my customer his car was done and advised him to sell it. It has 233,000 miles on it. I told him the transmission would probably be next. They are notorious for bad transmissions, it is a Taurus after all. Lol
Apr 13, 2016 at 11:17 PM
  • 55,658 POSTS
Glad we can help please use 2Carpros anytime we are happy to assist
Apr 17, 2016 at 11:41 AM
