Turn signals not working?
DRKORAF
  • FORD TAURUS
The hazzard lights and turn signal lights on my 1995 Ford Taurus GL wagon, 3.0 L w/101, 00 miles suddenly stopped working. All interior and exterior light bulbs and fuses are good and hi/low headlights, parking lights work fine HOWEVER only the top rear/middle cargo hatch LED brake light works, the two main rear brake lights/turn signals do not work even though bulbs are good. All other electrical systems appear to be working fine including horn, heater, AC, radio, alternator, wipers, cruise control, defroster, lighter, etc.
What is causing the problem and what/where is the fix? Is it the brake light switch and would it have to be replaced (can I do it?) Or is there a breaker somewhere I can reset?
Wednesday, December 2nd, 2020 AT 8:49 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
If all fuses are good then you need to test for power through the brake light switch. If brake and turn arent working it sounds more like the turn signal switch is the problem
No hazards-could be the flasher, for the brake lites maybe from the brake switch to the bulb socket an open circuit
Do what Mr. Jack recommended
