1995 Ford Taurus Oil leak
FT95
  • 1995 FORD TAURUS
  • 6 CYL
  • FWD
  • 60,000 MILES
I noticed that around my oil pan it is all wet.I am assuming the gasket is leaking. Is this a big job?I noticed part of the exhaust is in the way. Is there anything else I should be removing before dropping the oil pan.
Monday, September 6th, 2010 AT 7:35 PM
  • 31,937 POSTS
Hi there,
Drain oil and remove filter, remover battery cable, starter and brace, remove torque converter cover, undo O2 sensor and remove exhaust, undo sump bolts and lower sump.
Mark (mhpautos)
Monday, September 6th, 2010 AT 7:53 PM
