[quote:999d06b5b9="blackop555"]if the oil soaked the starter it can cause poor connection. also if it gets inside it can short out teh coils and such.
does starter turn on at all?[/quote:999d06b5b9]
as far as i can tell there is a tick when i try to start it only one tick! each time i try. I also tried to jump start the car thinking the battery was bad with no results same tick. is there anything else i can do to troubleshoot this problem? i would hate to spend 150$ on a starter if thats not the issue. However the car has made that screeching sound when trying to start it earlier last year. I did remove the starter today there is a burnt smell inside it is it hard to take apart to see inside?
Apr 5, 2009 at 10:24 AM
