2000 Ford Ranger Front Bearing Hum
NMB
I have a 2000 Ranger with 113000 miles with a left front bearing humming from what I've heard this is sold only as a complete hub replacement. Is the new hub pressed on and is it a job that can be done without taking it to a garage Also is ther a way to find out if the truck was built before 6/22 or after
Thanks
nmb
Dec 15, 2006 at 11:31 AM
CARUNDELL
  • 602 POSTS
[quote:97cf615468="nmb"]I have a 2000 Ranger with 113000 miles with a left front bearing humming from what I've heard this is sold only as a complete hub replacement. Is the new hub pressed on and is it a job that can be done without taking it to a garage Also is ther a way to find out if the truck was built before 6/22 or after
Thanks
nmb[/quote:97cf615468]
Hey nmb,
The hub and bearing assy should be bolted in and may take a bit of "persuasion" to get out (rust/corrosion), if your truck has ABS then the sensor/harness will come w/ the hub. Don't forget to torque the axle nut to spec!
Chris
Dec 15, 2006 at 8:20 PM
NMB
Thanks for the info now I just need to find out if it's 4w antilock brakes and if it was built befor or after 6/22
Dec 16, 2006 at 1:44 AM
Suggested Repair
The hub and bearing assembly is bolted in, not pressed on, and can be replaced at home. It may need extra force because of rust or corrosion. If the truck has ABS, the sensor and harness come with the hub. Torque the axle nut to specification.
Conversation Summary
The owner of a 2000 Ford Ranger with 113,000 miles reports a humming left front bearing and asks whether the replacement hub is pressed on, whether the job can be done at home, and how to determine the build date. The expert says the hub and bearing assembly is bolted in and may be stuck from corrosion; if equipped with ABS, the sensor and harness come with the hub, and the axle nut must be torqued to specification. The build-date and four-wheel ABS questions were not answered.
