1994 Ford Ranger Wheel Bearing Nut Backs Off
FORD
STUDLY0618
My front wheel bearings keep coming loose. I take the assembly apart, retighten the nut, and install all the parts back properly. Then as soon as I go down the road again I can hear grinding again. When I get back, the nut has backed off somehow even with the key inserted.
How does this keep happening?
Dec 14, 2006 at 2:24 PM
CARUNDELL
  • 602 POSTS
[quote:75f6481775="studly0618"]My front wheel bearings keep coming loose. I take the assembly apart, retighten the nut, and install all the parts back properly. Then as soon as I go down the road again I can hear grinding again. When I get back, the nut has backed off somehow even with the key inserted.
How does this keep happening?[/quote:75f6481775]
Hey studly,
Is this a truck? 4X2 or 4X4? or a car?
Chris
Dec 14, 2006 at 8:05 PM
STUDLY0618
It is a 1994 Ford Ranger 4x4 with about 120k miles.
Dec 15, 2006 at 7:41 AM
CARUNDELL
  • 602 POSTS
[quote:3d7f989274="studly0618"]It is a 1994 Ford Ranger 4x4 with about 120k miles.[/quote:3d7f989274]
Hey,
Sounds like the "locking pin" on the inner nut has broken. I recommend you replace the inner nut and be sure to torque this one to spec!
Chris
Dec 15, 2006 at 7:53 AM
Suggested Repair
Replace the inner spindle nut if its locking pin is broken, and torque the inner nut to specification.
Conversation Summary
The owner of a 1994 Ford Ranger 4x4 says the front wheel bearings loosen and grind after the nut is retightened, even with the key installed. The expert says the locking pin on the inner nut may be broken and recommends replacing the inner nut and torquing it to spec.
