2000 Ford Ranger Clicking When Backing Up
RANGER 00
I have a 2000 Ford Ranger, 4X4, Automatic, when I back up with the steering wheel turned there is a "clicking" sound that comes from the front driver's side wheel. :cry: After removing the hub cover on the alloy wheel it seems warm ... the hub was warm compared to the other side before removing it. Could this be a wheel bearing...or brakes...any suggestions or advise is appreciated. Thank you. :wink:
Aug 19, 2007 at 5:42 PM
SERVICE WRITER
  • 9,123 POSTS
The Ranger wheel bearing are pretty dependable. Try to get a quick touch on the rotors to see if there is a heat difference with them. I am inclined to thenk the pads aren't sliding as well as the should and the movement you hear is the pad shifting.
Aug 19, 2007 at 10:25 PM
Suggested Repair
Compare rotor temperatures for a heat difference. The clicking is more likely from brake pads that are not sliding freely and shifting than from a wheel bearing.
Conversation Summary
A 2000 Ford Ranger 4x4 clicks at the front driver's side wheel when backing up with the steering wheel turned, and that hub feels warmer than the other side. The expert notes Ranger wheel bearings are generally dependable and suggests checking the rotors for uneven heat, suspecting brake pads that are not sliding properly and shifting.
