I have a 1987 ford ranger 2.3l efi. It was running fine and just stopped. It will not hit a lick. I checked the spark and a nice blue streak. Checked the fuel and replaced the fuel filter, low volume fuel pump, and the pressure regulator. Checked the timing and the timing belt both are where they are supposed to be. Changed the spark plugs. Had the control module checked it's o.k. Changed the coil. Checked the rotor button and cap, they are o.k. Made sure the distributor is tuning. Checked the pulse on the injectors and they are pulsing. Just not sure what to check next. Can you help me? I'm going nuts and broke tring to get my truck running again. Thank you for anything you can help me with.
Feb 17, 2007 at 2:58 PM
