1987 Ford Ranger No Spark to Plugs
ROAMER
My son has a 87 ford ranger 2.9 v6 it was running & he turned it off & it wont start we replaced dist cap coil & module & it still has no fire to the plugs any ideas ?
Feb 25, 2007 at 3:16 AM
CHEVY22
  • 1,375 POSTS
i would check power into the module check the connector for damage , you can pulll the connector and proble the incoming power and plug it back in and check the power going to the module and check all fused if you have fuel and no fire start there and let us know
jim
Feb 25, 2007 at 5:05 AM
ROAMER
There is fire going to the module & fire from the coil but there is no fire going to the plugs could it be a bad dist ?
Feb 25, 2007 at 9:23 AM
CHEVY22
  • 1,375 POSTS
very possible , if you have a test light you can pull the plug from the dist have someone crank it and see if you have power out or a pulse from it , i think were getting close
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 25, 2007 at 9:34 AM
Suggested Repair
With spark at the coil but none at the plugs, test the distributor output with a test light while cranking for a pulse or power out. If there is no pulse, suspect a bad distributor. Also verify module power, connector condition, and related fuses.
Conversation Summary
A 1987 Ford Ranger 2.9 V6 stopped starting after being shut off and has no spark at the plugs despite a new distributor cap, coil, and module. The owner confirmed power to the module and spark from the coil. The expert advised checking module power, connectors, and fuses, then testing the distributor output for a pulse while cranking as a likely next step.
