Ford Ranger No Start No Fuel or Spark
DEADKINS
1900 Ford Ranger, 2.9 L, Automatic, 95000 Miles.
Truck will not start. No power to fuel pump, no power to ignition. Found no power was coming from the computer through the fuel pump relay, so I replaced the computer.
When I turn the key on, all the lights illuminate as normal on the dash. Engine cranks fine, fuel pump relay closes. No power through contacts of fuel pump relay and no ignition spark. Applied power to the terminal of the relay and the fuel pump will run, indcating the wires are okay from the relay back. Verified the "crash" switch under the right kick panel was not tripped.
Replaced, fuel pump, fuel pump fuse, computer, fuel pump relay. Vefied power at relay. (relay is closing) Verified fuel pressure (fuel pressure only when power is applied with a jumper @ relay). Replaced computer. All are present or okay.
My best guess now, is that power to the fuel pump and ignition is being stopped somewhere.
Additional information, alternator replaced 6 mo. ago. Both heads, timing chain and gear and distributor replaced 13 mo. ago.
Any advice you can add would be grately appreciated.
Mar 27, 2006 at 9:51 AM
  • 75,988 POSTS
[quote:ba2095925f="deadkins"]1900 Ford Ranger, 2.9 L, Automatic, 95000 Miles.
Any advice you can add would be grately appreciated.[/quote:ba2095925f]
Check for battery power to the PCM that controls the memory at all times.
Mar 27, 2006 at 11:59 AM
DEADKINS
[quote:f4735b8d81="rasmataz"][quote:f4735b8d81="deadkins"]1900 Ford Ranger, 2.9 L, Automatic, 95000 Miles.
Any advice you can add would be grately appreciated.[/quote:f4735b8d81]
Check for battery power to the PCM that controls the memory at all times.[/quote:f4735b8d81]
Would you have any idea wher it originates? A wire color? I have a Haynes Maunal, and most of the schematics are not accurate.
Thanks
Mar 29, 2006 at 11:47 AM
  • 75,988 POSTS
Cannot recollect-its at the end of the connector-I think! its a white wire. Disconnect the battery,then unplug all the connectors from the computer, now connect battery find the white and stick a test lite to it.Also make sure the PCM/ECU is ground properly.
I'll be looking for that Info
Mar 29, 2006 at 12:09 PM
  • 75,988 POSTS
[quote:c004c8f79d="deadkins"][quote:c004c8f79d="rasmataz"][quote:c004c8f79d="deadkins"]1900 Ford Ranger, 2.9 L, Automatic, 95000 Miles.
Any advice you can add would be grately appreciated.[/quote:c004c8f79d]
Check for battery power to the PCM that controls the memory at all times.[/quote:c004c8f79d]
Thanks[/quote:c004c8f79d]
Fuse 19 in the central fuse box feeds the PCM diode coming from the ignition switch its red/light green wire. Also there's a black/yellow wire coming from the diode to the PCM relay.Then a red wire coming from the relay to the PCM. The red wire feeds pin#'s
71 and 97 on the PCM
HTH/Good LUck!
Rasmataz
Mar 30, 2006 at 2:20 PM
Suggested Repair
Check constant battery power to the PCM keep-alive memory circuit and confirm the PCM is properly grounded. Inspect central fuse box fuse 19, the PCM diode fed from the ignition switch by the red/light green wire, the black/yellow wire from the diode to the PCM relay, and the red wire feeding PCM pins 71 and 97.
Conversation Summary
A Ford Ranger 2.9L cranks but will not start, with no power through the fuel pump relay contacts and no ignition spark. Dash lights work, the inertia switch is not tripped, and the pump runs when the relay is jumped. The owner had already replaced the fuel pump, fuse, relay, and computer. The expert advised checking constant PCM memory power and grounds, then fuse 19, the PCM diode and relay wiring, and power at PCM pins 71 and 97.
