1997 Ford Ranger AC Always On
CAPTNPETEE
Hi there. I have a '97 Ford Ranger (2.3L, Manual, 167K) which, no matter what setting I use, i.e. heater on high, fan on 2, bi-level vent, will have the AC Compressor engage. (This scenario is true no matter what settings...) AC works fine... when I want AC and set to those parameters I get nice and cold. But even when I want just outside air or inside recirculation, or heat, it's always pre-cooled by the AC compressor engaging. When I turn the system off (fan sw. off) then the compressor is off also. Any suggestions? Easy solution?
Apr 18, 2007 at 10:33 AM
MERLIN2021
  • 17,250 POSTS
Little more info needed! Is this an auto climate control system?
Apr 19, 2007 at 9:43 AM
CAPTNPETEE
Thanks for the replies.
To merlin2021, no, it's all manual. Three controls, one for temp, one for fan speed, and one for vent control.
To justanold, yes, factory installed. But I am a little unclear... if I read you correctly, then although I am turning on heat at bi-level, my a/c compressor will engage? So I am heating precooled air? Not logical... help me understand.
Apr 20, 2007 at 6:30 AM
MERLIN2021
  • 17,250 POSTS
If it is set up as an always on a/c it's done to remove moisture from the cars interior. Keeps windows from fogging.
Apr 20, 2007 at 10:24 AM
CAPTNPETEE
Wow. Well, I see the logic now, just the first time I've encountered this approach. Means that everything is working as it should.
Thanks for taking the time, guys.
Apr 20, 2007 at 5:48 PM
Suggested Repair
No repair is needed. On this manual climate system, the compressor is designed to engage whenever the fan is on so it dehumidifies incoming air and helps prevent window fogging. Confirm cooling still works and that the compressor stops when the fan is switched off.
Conversation Summary
The owner of a 1997 Ford Ranger with a manual climate system reported that the AC compressor engages on every setting, including heat, outside air, and recirculation, whenever the fan is on. Cooling works normally and the compressor stops when the fan is off. The expert explained that always-on AC is used to remove moisture and keep windows from fogging. The owner accepted that the system is operating as designed.
