2003 Ford Ranger AC Not Cold
TAKEH2003
  • 5 POSTS
I have 2003 Ford Ranger 4.0, my air conditioner wasn't blowing cold air, I took it to the dealer the mechanic told me that the compressor clutch had falling off and I should replace the compressor and clutch for about $1,000.00. I took the car home, asked my week end mechanic friend, he said I could just replace the clutch, since only the outside part of the clutch is missing, the pulley and other piece are still there. Can I just replace the outside piece or do I have to replace the whole clutch assembly?
Thanks
May 8, 2006 at 3:19 AM
LOSONE
  • 1,616 POSTS
It is almost impossible to replace the clutch without some special tools and a lot of skill.
It is MUCH cheaper to buy a rebuilt compressor with clutch. You can get one for around $200.00
May 8, 2006 at 8:28 AM
TAKEH2003
  • 5 POSTS
Only the hub is missing, it looks like the bolt came off and the hub just fell off. Can I just replace the hub?
May 9, 2006 at 1:00 AM
Suggested Repair
Replace the compressor with a rebuilt unit that includes the clutch rather than trying to replace only the missing clutch hub. Clutch replacement is difficult without special tools and skill, while a rebuilt compressor with clutch is much less expensive than the dealer quote.
Conversation Summary
The owner of a 2003 Ford Ranger said the air conditioner was not blowing cold. A dealer reported that the compressor clutch had fallen off and quoted about $1,000 to replace the compressor and clutch. The owner asked whether only the missing outer clutch piece or hub could be replaced. The expert advised that clutch replacement is nearly impossible without special tools and skill, and recommended a rebuilt compressor with clutch for around $200.
