1997 Ford Ranger HVAC Controls Fail
TIM55ECK
I have a 97 Ford Ranger. 100500 miles 4.0 liter. The problem I am having is that out of the three controls on the dash this is how they work. The fan knob works fine , the temperature knob has no control. All I get is hot air no matter what. The contol switch for a/c heat etc. It will trun off the over all a/c and heat but all I ever get is defrost. So this is how it works Defrost with high heat blowing or nothing at all
I have taken out the panel and replaced it with no results. It still does the same thing. I am told that this may be a vaccum problem . Where do I start if this is so.
Apr 11, 2007 at 8:43 AM
2CARPRO JACK
  • 11,533 POSTS
There is a small vacuum source line under the hood for the controls. Usually comes through the firewall near the heater hoses or a/c lines. Probably broken, cheap plastic and very hot under the hood
Apr 12, 2007 at 1:22 AM
Suggested Repair
Inspect the small vacuum source line under the hood that supplies the HVAC controls. It usually passes through the firewall near the heater hoses or A/C lines and is often cheap plastic that breaks from under-hood heat. Replace any broken section of the line.
Conversation Summary
The owner of a 1997 Ford Ranger reports that the blower works, but the temperature control always delivers hot air and the mode switch only provides defrost or shuts the system off. Replacing the control panel did not help. The expert advises checking the small vacuum supply line under the hood, which typically runs through the firewall near the heater hoses or A/C lines and often breaks because it is plastic and exposed to heat.
