2000 Ford Ranger Theft Light and Low Heat
KALUDJAK
  • 9 POSTS
Why is my heater on my Ford Ranger model 2000 so low even though the heat is on high. Also the fuel pump keeps shutting off after I start it and it won't start again, and the theft light is blinking. Please help
Jan 9, 2007 at 1:48 AM
CARUNDELL
  • 602 POSTS
[quote:6f251f888b="kaludjak"]Why is my heater on my Ford Ranger model 2000 so low even though the heat is on high. Also the fuel pump keeps shutting off after I start it and it won't start again, and the theft light is blinking. Please help[/quote:6f251f888b]
Hey lucy,
Please describe some more detail as to your heating problem. As to the other issue, your truck has gone into "theft mode" and usually its cause by a faulty "sensor" in the ignition lock cylinder assy. I have to recommend you take it to a ford dealership for diagnosis and repair for that issue. Let us know
Chris
Jan 9, 2007 at 3:34 AM
KALUDJAK
  • 9 POSTS
My heater is on to the max but it's like on real low, no heat practically, plus the fuel pump keeps shutting off after I start and then it won't start
Jan 9, 2007 at 3:47 AM
CARUNDELL
  • 602 POSTS
[quote:1c88f3ad1c="kaludjak"]My heater is on to the max but it's like on real low, no heat practically, plus the fuel pump keeps shutting off after I start and then it won't start[/quote:1c88f3ad1c]
As in the blower is cranking out air but the actual heat is not what it should be?
Yes, when the truck goes into theft mode it kills the fuel pump, thats why the theft light is flashing
Chris
Jan 9, 2007 at 4:04 AM
KALUDJAK
  • 9 POSTS
It goe's on and very little heat, not what it should be. I guess somehow my husband can reset the anti theft or whatever to have my truck running again, we don't have a repair place up here where I live, everyone doe's there own vehicles. No manual to follow either, they guy we bought it from lost it.
Jan 9, 2007 at 5:35 AM
Suggested Repair
The blinking theft light and fuel-pump shutoff indicate the truck has entered theft mode, usually from a faulty sensor in the ignition lock cylinder. Have a Ford dealer diagnose and repair that system. The weak heat was not diagnosed, so no heater repair was recommended.
Conversation Summary
The owner of a 2000 Ford Ranger reports almost no heat with the heater on high, plus a fuel pump that shuts off after starting so the truck will not restart, with the theft light blinking. The expert says theft mode kills the fuel pump and is usually caused by a faulty ignition lock-cylinder sensor, and recommends Ford dealer diagnosis. The owner confirmed the heat output is weak and said no nearby shop or manual is available.
