1996 Ford Ranger A/C Blows Hot Air
TODDJ67
1996 Ford Ranger 4 cylinder 99,000 miles. My A/C only blows hot air, I have had the A/C system checked, the compressor is good, there are no leaks, and the freon is topped off. At first it would alternate between cold air, no air, and hot air, then it went to totally hot air. Living in Phoenix this is unbearable. Please help!!!
May 27, 2007 at 3:13 PM
98RANGERXLT
  • 301 POSTS
Your mixer door may be stuck
May 31, 2007 at 1:00 PM
TODDJ67
I found the problem, there was a vacuum hose that had been rubbing on something and rubbed a hole through it. Thanks
May 31, 2007 at 5:36 PM
Suggested Repair
Inspect and repair or replace the vacuum hose that had rubbed through, since that leak prevented proper blend-door control and left the A/C blowing hot air.
Conversation Summary
A 1996 Ford Ranger with about 99,000 miles blew only hot air after the A/C had alternated between cold, no airflow, and hot. The compressor, refrigerant charge, and leak check were reported good. An expert suggested a stuck mixer door. The owner later found a vacuum hose that had rubbed a hole through it.
