please and thank you,
James Blackwell
Check the pressure switch and accumulator, then inspect the under-dash vent flaps that may be switching to the heater vents and restricting the evaporator. Also test the thermostatic switch by the evaporator, which may be faulty or adjustable. Use a Haynes heating and air conditioning manual to troubleshoot with gauges.
A 1995 Ford Ranger 2.3L with high mileage suddenly blows only hot air. It will not accept a recharge, the airflow switches between the A/C and heater vents on max A/C, and the compressor runs about five seconds then shuts off for about 30 seconds. The expert suggested checking the pressure switch, accumulator, under-dash vent flaps, and evaporator thermostatic switch, and following a Haynes HVAC troubleshooting guide.
