1998 Ford Ranger Draining Power
19,500 MILES • 6 CYL • 2WD • AUTOMATIC
FRANK CARDENAS
My truck seems to be losing battery power. If I leave my door open for 5 min, it drains battery power. Truck will start but shakes and turns off so I have to keep a high idle and drive for a couple miles to charge battery back up and then it's back to normal idle. I rplaced battery with new one. Never had problem before.
I had a/c service done a while back and wonder if related. Changed the whole hose assembly.
Thanks in advance for any help!
Jul 31, 2008 at 5:17 PM
  • 31,937 POSTS
Hi there,
Have the alternator charge rate checked, as well as all the battery terminals make sure that they are clean & tight, ask your mechanic to do a current draw test and include the alternator as well as a faulty diode will cause a current drain.
mark (mhpautos)
Jul 31, 2008 at 9:30 PM
