2000 Ford Ranger wierd idling
JGARNER3189
  • 2000 FORD RANGER
  • 6 CYL
  • 4WD
  • 112,000 MILES
Alright my check engine light is on and my truck idles around 700 rpm whatever gear im in. I have changed the fuel pump, fuel injector, fuel filter, plug and wires, and o2 sensor. I dont know what else to check.
Thursday, May 14th, 2009 AT 8:12 PM
KHLOW2008
  • 41,814 POSTS
Hi jgarner3189,
Thank you for the donation.
When the CEL is showing, a component in the engine management system is malfunctioning and you need to retrieve the diagnostic Trouble Code to know what is causing it.
Your local Autozone parts outlet should be able to do the scan for you. Let us know the exact DTC and we shall see what needs to be done.
Friday, May 15th, 2009 AT 11:05 AM
