Hi pgoss@bellsouth. Net and welcome to 2carpros
Remove the inertia switch and check for power on the dark green and yellow wire on the connector if its present-replace the inertia switch-not there-check the fuel pump relay and fuel sys/anti theft fuse no.9 20amp
Good Luck
Sunday, October 26th, 2008 AT 8:21 PM
