Tuesday, October 26th, 2010 AT 2:51 PM
I have a slight hesitation when I am giving the truck gas under a load. It kind of jerks like it is starving for fuel when you accel hard. If you take off easy it is fine I have replaced the fuel filter & air filter.I have no codes I just wondered if maybe the filter on the fuel pump might be clogged or maybe a bad injector. If it might be the fuel pump filter would it be easier to pull the bed or drop the tank?How would be the best way to check the problem? Thanks Bruce
