Speedometer not working
JORSHEP
  • 8 POSTS
We drove it to advanced auto and they used their meter. The only code that came up was the Exhaust Gas Recirculation system (EGR). The meter didnt pick anything up to do with the speedometer.
Monday, June 12th, 2017 AT 4:07 PM (Merged)
BLACKOP555
  • 10,371 POSTS
Egr valve will not cause that!
It is possible that if a part is wrong it wont throw a code, bad o2 sensors do that lots of the time.
Best way is to manually test um.
JORSHEP
  • 8 POSTS
How do you manually test?
ROVING RANGER
  • 2000 FORD RANGER
  • 6 CYL
  • 185,000 MILES
Electrical problem
2000 Ford Ranger 6 cyl Two Wheel Drive Automatic 185000 miles
The truck has brief intermittant episodes where the antilock braking system light comes on, the speedometer doesn't work and the automatic transmission doesn't shift properly. As I recall isn't there an electrical component under the drivers seat that controls all three of these issues? Is that somethiing that can be easily replaced?
BLACKOP555
  • 10,371 POSTS
Now were talking.
First ill have to ask again you have a tachometer? And if so does it function?
Ill post the steps first then post back and see if I can find some diagrams!
ROVING RANGER
JORSHEP
  • 8 POSTS
I do have one but its from the late 70's, early 80's. If the steps are simple, ill just buy one.
BLACKOP555
  • 10,371 POSTS
First a tachometer is easy easy easy to install, but I was asking if you had a factory one, to see if it was working either.
Get back to me so we can get started.
DORKSISTER
  • 2000 FORD RANGER
Electrical problem
2000 Ford Ranger 6 cyl Two Wheel Drive Automatic 108 k miles
My speedometer isn't working, can I fix it at home? How? And How much? Thanks for any help that you can give me
DAVE H
  • 13,384 POSTS
The instrument cluster utilizes a self-diagnostic system which may store a Diagnostic Trouble Code (DTC) if a problem exists in the system. DTCs may be retrieved using New Generation Star (NGS) tester, or equivalent scan tool, and Data Link Connector (DLC)
