Hello -
It appears for your model that you have a speedometer cable. I would imagine it is broken and needs replaced.
Now all you would be replacing is the core itself.
You would have to remove the cluster and disconnect it at the transmission. The cable core would be pulled through the new pushed through. Make sure you lubricate.
Monday, December 8th, 2008 AT 6:48 PM
