1999 Ford Ranger 98 Ranger speedometer/ battery connection
YELLAH12
  • 1999 FORD RANGER
  • 6 CYL
  • 4WD
  • 150,000 MILES
First off it was a stormy night and water was standing. I parked my truck and turned it off having no problems. When I went to start my truck 20mins later it was acting dead the inter lights will come on but very dim and the open door chime will work the inside light display is on but my headlights wont work!I jumped the truck next I put the truck in drive and the speedometer gos from 0-60mph back and forth when only going 20mph! Now it wont turn back on will make the crank sound when turning over the key just wont start. When I try to start ot the positive battery conncter gets hot and smokes a little. What is going on! Just got a new oil change
Sunday, August 15th, 2010 AT 9:00 AM
LEGITIMATE007
  • 5,121 POSTS
Hi, I think you may have an alternator problem, or even a combination of alternator and battery, . We need to fix this problem otherwise it may cause some damage to the computer. I think the voltage regulator may be bad. The best thing to do is bring it to autozone and have them test it.
Sunday, August 15th, 2010 AT 10:23 AM
YELLAH12
I did forget to tell you the ABS light turned on too!
Sunday, August 15th, 2010 AT 10:27 AM
LEGITIMATE007
  • 5,121 POSTS
That may or may not be related to the alternator/battery
Sunday, August 15th, 2010 AT 10:32 AM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/how_to_test_alternator.htm
Sunday, August 15th, 2010 AT 10:33 AM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/battery.htm
YELLAH12
Thank you ill check out the videos! Also a while ago when driving my truck started julting hard when pushing on the gas. Like a misfire sound. I changed the spark plugs but they may be bad again
Sunday, August 15th, 2010 AT 10:47 AM
LEGITIMATE007
  • 5,121 POSTS
Again, that too may be an alternator problem. But like you said plugs, wires(arcing). Could be many things. Check that out first though
Monday, August 16th, 2010 AT 9:43 AM
