1991 Ford Ranger no start
DUPONT91
  • 1991 FORD RANGER
Electrical problem
1991 Ford Ranger 4 cyl Two Wheel Drive
the truck starts fine and runs fine but, when it runs for awhile and shut it off. It will not start agian but, it will after it sets for awhile, the fuel pump works
Wednesday, January 28th, 2009 AT 3:53 PM
Check the fuel pressure make sure its within specifications then comeback
Wednesday, January 28th, 2009 AT 4:23 PM
DUPONT91
Fuel pressure ok, there is no spark
Thursday, January 29th, 2009 AT 11:43 AM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, January 29th, 2009 AT 1:59 PM
