1988 Ford Ranger 1988 Ford Ranger 2.9 V6 Wont start when ho
BOATANCHORS66
  • 1988 FORD RANGER
Electrical problem
1988 Ford Ranger 6 cyl Four Wheel Drive Automatic
I have a 1988 ford ranger 2.9 v6. It runs fine and drives fine, But once the engine gets to normail operating tempature and I shut it off it will not start back up, I have replaced the TFI module, The Coil Pack the Condensor and the Air control valuve and the starter and still have not solved the problem. I check and it is getting spark to the spark plugs and it is getting fuel to the injectors. Please any help would be greatly appreciated. Thanks Chris
Sunday, September 13th, 2009 AT 10:57 AM
Do you have access to a fuel pressure gauge if so hook it up on the fuel pressure test port and read off and give me the readings we start here
Sunday, September 13th, 2009 AT 11:20 PM
BOATANCHORS66
I tested the pressure of the fuel to the injectors and it is holding right around 40 lbs.
Monday, September 14th, 2009 AT 3:00 PM
I tested the pressure of the fuel to the injectors and it is holding right around 40 lbs. Is this while engine is idling if so you're good to go.
Hook up the gauge again and when you shut off the engine monitor the pressure did it drop to zero instantly?
Also check and test the BMAP and TPS sensors to include the CTS.
Monday, September 14th, 2009 AT 5:08 PM
BOATANCHORS66
It was a bad ground cable
Saturday, September 19th, 2009 AT 8:52 AM
