HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Engine
Symptoms
Not Running
SPONSORED LINKS
88 Ranger won't start
RANGERDAWG
MEMBER
1988 FORD RANGER
Have 88 ranger started this morning, then stalled now won't start? It is an 88 ford ranger stx 2.9 liter v6
Friday, August 17th, 2007 AT 2:34 PM
MERLIN2021
MECHANIC
Check for spark at the plugs, and fuel pressure.
SPONSORED LINKS
Friday, August 17th, 2007 AT 2:35 PM
RANGERDAWG
MEMBER
New fuel pump, fuel fiter, an spark r there.
Friday, August 17th, 2007 AT 5:03 PM
JD329
MEMBER
New fuel pump, fuel fiter, an spark r there.[/Quote:df30d93ddb]
Try the fuel pump relay in or around the fuse box.
Thursday, August 23rd, 2007 AT 7:44 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1988 Ford Ranger 1988 Ford Ranger 2.9 V6 Wont Start...
Electrical Problem 1988 Ford Ranger 6 Cyl Four Wheel Drive Automatic I Have A 1988 Ford Ranger 2.9 V6. It Runs Fine And Drives Fine...
Asked by
boatanchors66
1988
FORD RANGER
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1988 Ford Ranger Wont Fire After Warm
This Truck Starts And Runs Good You Can Drive It 2 Miles Or 20 And It Runs Good Until You Turn It Off Then It Will Not Start It Just Turns...
Asked by
rdant333
1 ANSWER
1988
FORD RANGER
1988 Ford Ranger Engine Start & Run Problem
Best Way To Explain Problem Is: Few Mo. Ago Truck Would Not Run Well, Finally Found Crack Between Valves In #2 Cyl. Removed & Had Repaired...
Asked by
harley661
1988
FORD RANGER
Electrical Issue
Positive Post Touched Hood And Killed The Engine. Now It Will Not Start. I Do Not Hear The Fuel Pump Kick In When I Turn Key. Any Help...
Asked by
Rocky the roofer
5 IMAGES
1988
FORD RANGER
1988 Ford Ranger Fuel Fillter
1988 Ford Ranger 4 Cyl Two Wheel Drive I Have A Ford Ranger That Will Not Start. Listening To It Sounds Like It's Not Getting Any...
Asked by
nathan flanner
1988
FORD RANGER
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
