1993 Ford Probe car stop won't start
MCCOYG1
  • 1993 FORD PROBE
  • 4 CYL
  • FWD
  • MANUAL
  • 195,000 MILES
While going down the road the car just stopped and the engine died and won't restart.
Friday, May 29th, 2009 AT 7:59 PM
The engine died and won't restart.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Friday, May 29th, 2009 AT 8:12 PM
MCCOYG1
Thank You will try that
Friday, May 29th, 2009 AT 9:02 PM
