1993 Ford Probe engine not firing
NANNANPAWPAW
  • 1993 FORD PROBE
Electrical problem
1993 Ford Probe 4 cyl Front Wheel Drive Automatic
my daughter was driving car stalled. It hasnt started since. It is not firing.I went to a salvage yard and looked at distributors. All 93s had one plug at the distributor. This car has two plugs going to the distributor. Evidently the engine has been changed along the way. How also can I find out what year model the engine is
Tuesday, August 12th, 2008 AT 8:50 PM
  • 31,937 POSTS
Hi there,
If you quote the engine No to your dealer they will be able to tell you the series of your engine. They will also be able to advise on where the engine no is, make sure you take it off the engine and not any paper work you have as that may be wrong.
Mark (mhpautos)
Wednesday, August 13th, 2008 AT 12:33 AM
