2005 Ford Sport Trac Keypad Code
FORD
KIMMYG1
I just bought a used 2005 ford sport trac. I need to get the 5 digit keypad number located on the computer module. Where is the computer module?
May 10, 2006 at 7:52 AM
LOSONE
  • 1,616 POSTS
It sticks in the fire wall on the passenger side, connector is in the engine compartment and the rest in the vehicle.
Check your door frame on the drivers side, they sometimes put the calibration code there.
May 10, 2006 at 9:58 AM
Suggested Repair
The keypad computer module is mounted in the passenger-side firewall, with the connector in the engine compartment and the rest inside the vehicle. Also check the driver's door frame, where the calibration code is sometimes posted.
Conversation Summary
The owner of a used 2005 Ford Sport Trac needs the factory 5-digit keypad code from the computer module and asks where that module is. The expert says it is in the passenger-side firewall, with the connector in the engine compartment, and suggests checking the driver's door frame for a posted calibration code.
