How do I find out what the keypad code is on my Explorer? When I bought it, it did not have the code or an owner's manual.
Feb 1, 2007 at 10:46 AM
Look for a factory sticker with the keypad code on the keyless entry module, GEM module, or PCM. If it cannot be found, a dealer can retrieve the code from the PCM with an NGS tester.
The owner of a 2003 Ford Explorer wants the factory keypad code, which was not provided at purchase and no owner's manual was included. The expert says the code is often on a sticker on the keyless module, GEM, or PCM, and a dealer can pull it from the PCM with an NGS tester if the sticker cannot be found.
