1998 Ford Explorer Check engine light is on. The codes are PO171 & PO174 bank 1 and bank 2 too lean. I've changed the Mass Air Flow Sensor, spark plugs, spark plug wires, oxygen sensors. I don't know what else to do. We have switched engines and the light was on before with the old engine & is on with the new engine. We did use the top part of the old motor, I'm thinking maybe the fuel injectors?
I had a vacuum test done too. That come back with no leaks. I've also changed a hose that was collapsed and that didn't do any good either.
Yes it is a 4.0 SOHC I'm just lost on what to do.
Sep 12, 2007 at 3:38 AM
