I just bought a used 2005 ford sport trac. I need to get the 5 digit keypad number located on the computer module. Where is the computer module?
May 10, 2006 at 7:52 AM
The keypad computer module is mounted in the passenger-side firewall, with the connector in the engine compartment and the rest inside the vehicle. Also check the driver's door frame, where the calibration code is sometimes posted.
The owner of a used 2005 Ford Sport Trac needs the factory 5-digit keypad code from the computer module and asks where that module is. The expert says it is in the passenger-side firewall, with the connector in the engine compartment, and suggests checking the driver's door frame for a posted calibration code.
