1996 Ford Mustang Heater Core Location
RYKEM
  • 7 POSTS
I have a 1996 ford mustang V6 and the heater core is gone out on it and I was trying to see where it was located on the car to fix it . Please help it is hot down here
Jun 10, 2006 at 9:54 AM
ELZIEW
  • 17 POSTS
Get yourself a good manual, They are a must for people that do their on repairs. good luck
Jun 11, 2006 at 5:32 AM
RUGBYRULES
  • 5 POSTS
i think its in the radiator...or thats where mine was when i had it replaced in my 1966 pontiac
Jul 27, 2006 at 4:33 PM
SERVICE WRITER
  • 9,123 POSTS
Should be in the firewall on the passenger side. Follow the heater hoses to where they disappear into the firewall, and you'll roughly know. Definitly get a manual for this or some kind of procedure. IF your in a bind, need to drive it and don't need heat, you can cut and splice the two lines together to bypass the heater core. Just becareful that the two lines are standard bulk hose for when you do replace the core. Sometimetime they are special dealer only lines that can get expensive and/or make more work that you wished for.
Jul 28, 2006 at 10:03 PM
Suggested Repair
The heater core is in the passenger-side firewall; follow the heater hoses to where they enter the firewall. Use a repair manual for the procedure. If the car must be driven without heat, the two heater lines can be cut and spliced together to bypass the core, but confirm they are standard bulk hose rather than expensive dealer-only lines.
Conversation Summary
The owner of a 1996 Ford Mustang V6 asked where the failed heater core is located. One reply recommended a repair manual, and another incorrectly compared it to a radiator on a different vehicle. The expert said the core is in the passenger-side firewall, advised following the heater hoses and using a manual, and noted a temporary hose bypass if heat is not needed.
